4010 radiator
2520-4010
The core on the 4010 diesel is shot....can't be repaired. I can get a complete radiator (made overseas) for around $500. I've also found a used radiator out of a 4010 LP. Is the only difference in the diesel and lp radiator the two holes in the top tank (for the on/off rods)? Or does anyone have any suggestions for help?
Thx for any/all advice!
I have been having good luck with A&I radiaters, they are made in Ireland. Stay away from China or India junk. $500 sounds high priced to me for a new one. 4010's diesel have a slight tendency to run hot if the fuel is turned up and the tractor is worked hard so maybe consider a 4020 radiater as it is slightly wider with more cooling.We found this out running a forage harvester in hot weather.Have the used radiater pressure checked and cooked out good by a shop,but beware some shops over pressure a radiater causing it to leak so they can sell you a brand new one as there is more profit in selling new ones than repairs.We have a shop in our area like that.I took a 2510 radiater in that was fine except that it was leaking on the top seam and they called back to say it was full of holes when checked,local Deere dealer said 80% of radiaters took there end up that way.
A couple years ago my neighbor bought an A$I radiator for his 4010. The overflow was in the wrong spot and he had to grind the notch out in the hood. It also has a baffle just in the neck so you can"t check the level of the antifreeze. He hasn"t had any trouble with it though. I bought a JD radiator and I still had to grind out a little of the hood. The radiator cap covers it up but i"m not real happy with it. It doesn"t have the baffle in the wrong place at least. I haven"t had any trouble with it either.
