4010-Rear wheels
Tom-730
Just bought a 4010 about month or so ago. Been spraying kroil oil on wheel bolts. Today tried to move the wheel. 3 bolts backed out fine, tightened the 2 jack bolts, then loosen then tighten again, one twisted off. I know this has been talked about before, just kind of wished I'd left alone. Only thing is the hub is past the axle about a half inch. Any ideas?
First do an archive search to learn more. Then drive the pinion bolt out (the one you use to move the wheel when it is loose). Then with the rack up, put a jack in between the cast wheel and the drawbar support. Jack it up fairly tight and then wail on the end of the axle with a big sledge. In your case you will have to have someone hold something against the axle to take up the space, like another sledge hammer. Many have had good luck with the half cut off pipe to just hammer on the wedge, but without an axle sticking out to guide it, that would be tough too.
Tom,
Like the guy said, jack the rear end up, as stable as possible, and gently rock the wheel on the axle, after applying penetrating oil. Also, try to hit the "chocks",(what I call them), which wedge onto the axle with oil also.
Everyone breaks off a bolt, here and there, if you turn wrenches long enough--it happens. Try to slowly work things loose. Had to adjust the rear wheels on my '69 4020, which is similar, approx. 3 years ago to plow, seems like they broke free in a similar manner with a little persuasion, and a 3/4" wratchet with an extension. Good Luck, and let us know if it works.
Matt
Loosen the three inside bolts and put a jack on the end of the axel housing to the cast wheel and then beat the end of the axel.
