4010-Rear wheels
Tom-730
I looked today at the 3 bolts on the backside, there are already 2 that are broke off. I got the third one out. I am letting the bolt that turns the little gear soak for a while. I will fill it up every couple days . Then I will try to drive the pin out.Will definitly need lots of patience
It sounds like you have a "tight"one,It's unusual for the inner bolts to be broken. Use a blunt 1/2" punch or a long 1/2" bolt with a squared off end(a rounded end will pein the pinon bolt's end)snap a good pair of vise grips to it and drive the pinion bolt out(don't forget the goggles),then smack the 3 big outer bolts with a big hammer a few times to shock the threads, and remove them ,try to get the remaining inner bolts out, set a jack from the lower hitch A frame to the cast hub,I use a floor jack and a 24" 2X6 to hold the blocking up in place, (keep the horazontal jacks pump on the lower side so it gets oil),be carful to keep every thing even so it don't kick out and get you,pump the jack till it's real tight and smack the end of the axle "real" hard and squarely on the end, this works, just takes a bit of getting it all together.
