4010 Roosa master not returning fuel
justsomeguy
My tractor sat too long and the fuel system became varnished heavily and needed cleaned. I went through the injection pump a few years ago and had it running great before this. Now I've cleaned the fuel tank, replaced the lift pump and filters and went through the injection pump and resealed and cleaned it again. Now no fuel comes out of the return fitting on the injection pump and it runs terrible and surges and won't rev past 1500 ram. Any ideas what to look at?
Is the metering valve free to move when the throttle lever is moved. To check, disconnect the return fuel line, three screws, take off back cover and look?
Yes metering valve is free, as are the rollers and pistons. The vane pump on top...should it be c side up, or cc side up? I have it c side up. How does fuel flow through to the return? I've put an air hose to the fuel inlet on the pump and put pressure on it and still nothing comes out the return.
If I had any ideas for you I would happily share them, but this time I don’t. My wife always says that I can’t go a whole day without making some sort of smart arse comment. You just happen to be on the receiving end of today’s.
Iirc they don’t return fuel constantly I’ve had the top line completely off the top of the injectors with 4020 3010 3020 4010 and there isn’t a noticeable puddle when I’m testing. One if I recall I was waiting on that actual line for an early one since it was around 700 bucks and nobody had one.
So that in itself probably is not an issue.
Is it possible that the air cleaner is plugged?
Is it new enough to have a paper filter or if you pull the oil cup off down below does it improve? It is the end of mud wasp season and those pipes can get plugged.
Linkage problem does foot throttle and hand throttle react the same?
Just a couple things to check you still might have a fuel problem but it’s possibly not. if she truly did sit for a super long time and varnish badly some injector testing fuel pump gone through dump the fuel and try again
4020 no start is the title of one similar post to search to find a similar example yours starts however but that shows you how bad they can plug up
It doesn't have a foot throttle so I can't check that. It is an oil bath air cleaner. I applied air pressure to the fuel inlet side of the injection pump for a few seconds to see if I could force fuel through to the return line and then started the tractor and it ran fine. Once it was all hooked back up it ran poorly again. I'm stumped. The return line to the tank is open. I blew air through it to check.
The 500b had a stuck loading valve awhile back and it got taken off and taken in to the injection shop. That might be what’s going on for you once I had it flowing good from the priming pump then it is kind of inspect main pump.
The return does not go back into the inlet it goes to the top of the tank the injection pump truly does not care about that return line
Is there a check ball in the return valve 90'elbow on the back cover on the injection pump? Take the elbow out run the tractor. Any difference?
Where is the loading valve? I can usually figure anything out. The first time I went through the pump when it sat because the plungers rollers and metering valve got stuck, it ran like a top. I feel like I did the same thing this time and it just won't run right.
Metering valve is what I meant I’m not sure why I was thinking loading was the name. The backhoe ran about 5 winters ago was acting up and I got it going enough to get it back to the farm and then it sat didn’t do any tile repair those dry years then now just lately after it’s been raining I had it stick again this time really really good wouldn’t fire at all. Took it off sent it to the pump shop and it’s been running great after that. He said metering valve was stuck. The backhoe had keyed shutoff as well that yours probably does not have. I made him put a new solenoid it didn’t look like it was in the best condition while he was in it.
Yes mine is mechanical shut off. Mine had a stuck metering valve last time I had to go through it. I had a devil of a time figuring out which way was correct for clockwise or counter clockwise putting it back together. I think I took it apart 5 times before I got it to run, but then it ran better than ever. I think the timing was off before. It has the internal advance so I set it a 8°. And the governor disk had disintegrated and plugged it all up so I switched it out for the basket type.
you have been farther into it than I would probably venture we do have a good local pump shop here that is rather reasonable. Some locations of this world are not as lucky.
