4010 vs 4020
Kory1998
Are the gear train quieter in the 4020 versus the 4010 have heard of this being an issue and plus are the gears different in the transmission design wise I know the part number don?t sub over for these tractors .
(quoted from post at 21:33:58 04/29/19) The 4020 is geared about 1/3 gear slower in each gear than a 4010. Tom
Tractordata (which has been known to have an error now and then) has it basically the other way, with the 4020 being FASTER.
That is interesting. I wonder if it has to do with tire size? Many 4010's were sold on 15x38 tires and most 4020's have 18x34 tires. My comment was made because I have both a 4010 and several 4020's with 18x34 tires and in the field have observed the 4010 being faster. It shows up in the 3010 and 3020 as well. It could also be comparing powershift speeds to syncro? Tom
You GOTTA read the fine print on EVERYTHING, Tractor Data is No exception! 4010 speeds are at 1900 rpm
PTO speed. 4020 was at 2500 transport rpm, so guess what? 4020 was a tic over 31% faster. 4020 did
state 15.5x38 tires on test tractor. 4010 said 13.6x38 was standard tire size on 4010 even though I
never saw a 4010 with them,but did not actually say what size was on test tractor, the PDF of the actual
test report would state that, but YOU can look that up. The 13.6 and 15.5's are supposed to both be the
same diameter, within a revolution or two per mile, so supposedly no difference in speed.
I ran the wheels off Dad's 4010 with 15.5's then jumped on one of 5 4020's or a 4320 the BTO neighbor
had all with 18.4x34's and never noticed much difference in speed. The 4010 of course had the third
reverse just below 7th gear that none of the 4020's/4320 had access to, gears were there, had to
grind/cut the range slot deeper.
I've never seen a 4010/4020 parts book, would not be surprised all the transmission and final drive
gears had the same tooth count.
[i:654c4848f0]The 4010 of course had the third
grind/cut the range slot deeper.[/i:654c4848f0]
Was it higher or lower than the other reverse? Any chance the 3020 has similar? (I'd love a lower reverse for the 3-pt snowblower)
I was told yrs back that all JD Syncro-range trans had four(4) reverse speeds if the sheet metal was removed to allow gearshift lever to move far enough down in shifter quadrant to access reverse.
