4014 excursion
redforlife
How many yesterdayers are following the 4014 to Ogden on you tube?
Glad to see the 4014 project done and operational. Never thought we would ever see a big boy operational again. It's truely a dream come true. And a timeless peice of history.
I just wish they would do more on their excursions. I don't see why they have to triple head in route (counting the modern deisel unit) and only pull 9 cars. I do understand that the passenger cars need the deisel unit for electricity use in the passenger cars. But is what I don't understand, is why only 9 cars pulled behind all that power. And why the 844 and 4014 are double heading in the same train. They use to do this with the 844 and 3985 also, if they were going to the same place. Wouldn't it make more sense to make up two trains and run one about 10 miles behind the other one? Give the rail fans a bigger thrill. After all, half the thrill is hearing the whistle. And that's rarely blown on the second engine when double heading. And one of those bright yellow extra water cars sure looks tacky in front of the second black locomotive when double heading in my opinion. Just my two cents. What do you think??
I would suppose it has to do with scheduling and money. The excursion trains probably have to operate within gaps of the freight train schedules and the diesel/electric is in the mix with the steamers to keep them moving in case anything goes wrong. Personally, if I had the chance to see the steamers, I wouldn't notice if there were pulling any cars or not!
I don't think they sound the same when not pulling a load. Especially when taking off from a stop. And these engines don't even know anything is behind them when pulling nine cars. Especially passenger cars which are lighter. I could understand the use of only one service crew at their whistle stops if they travel together. But in reality, whistle stops are usually always done where it is double tracked. And I would think it would be more convenient for the service crew to have the engines parked side by side. Then they wouldnt have to cart their equipment from the service car all the way back behind the deisel unit when everything is tripple heading. And as far as scheduling, I don't really see that running two trains, one right behind the other in the same direction, on the same track would be much of an issue. Even 10 miles apart would only mean 10 more minutes.
I don't know. Some of this don't make much sense to me. Just think they could orchestrate something a little neater when they actually do send these things somewhere.
I've been following it!
Sure glad the UP is willing to invest in their history, that's a huge chunk of money they've spent there!
I don't understand why they would double head them, the makes no sense.
But I suspect the diesels are along for the ride because of some rules and regulations, some auto speed thing that the steamers don't have.
And there is the trust issue. A lot can and does go wrong on the steam engines.
But still, I think they should go it alone, just like it was in the day. I would gladly do without air conditioning for the chance to ride behind one.
Now, lets not get into what I would do to get to ride in the cab! LOL
the way that i understand it is that the extra cars are to supply extra braking power, and the diesel unit is for power in case of break down on main line, have to keep the main line clear....
The goal here is to get a virtually UNTESTED locomotive to an event on time. If you're the one responsible for making that delivery, you are going to take every precaution.
Besides, you know what you see even LESS of, than a steam locomotive tooting its whistle? A steam DOUBLEHEADER, let alone one of this magnitude.
You're completely ignoring the once-in-a-lifetime occurrence that's right before your eyes.
A couple of things:
4014 isn't very proven yet. If you restored a rare tractor, and finished the week before a big show where it would be scrutinized by a lot of the "world", you'd take precautions, too, right? There were some issues with a blown packing on the front engine, and likely other stuff not reported, so it is probably best to play it safe.
I've read (via Trains Magazine) that the diesel is functioning in dynamic braking mode at least some of the time, so it is adding additional load to the train than what it seems.
Last, remember they are a working railroad, and they need to schedule other trains etc. Doubleheading requires less crew (no extra conductor, etc) less time tied up, and if one engine fails, another can get things limped into a siding somewhere. No, it isn't visually appealing as it could be, (with the diesel and water cars) but it is hot steam, and that isn't every day. I'll take it.
I'm sure the time will come when she'll be strapped to a string of hoppers and put to work. In the meantime, I'm glad they got the thing running and am hoping she makes Ogden. The restoration was a huge undertaking, and came right down to the wire.
Probably they expect enough passengers to fill two cars and figure that seven spares are plenty.
The 4014 went down to the wire and was untested.
So they cancelled 844's lone trip and double headed for safety
The diesel is plan "B" and also provides Dynamic braking on hill's as per FRA rules.
The first car after the diesel, is the Art Lockman
Which is a machine car equipped with all the tool's parts, and complete machine shop, named after Art who is still living
And was on hand for the christening at Cheyenne who is in his
Nineties.
He was the last UP Steam Maint. shop foreman and hired in the forties
When the first Big Boy's were delivered.
The next car is the Generator car that supplies power to all the coaches.
There were some minor issues but there working them out.
Also something to do with the driver rod bearings needing to be slowly broke in so there not hammering on 4014 yet.
I've seen them stop and grease those rods more than I ever had.
The big event starts Thursday at Ogden UT where the pay off comes
In the form of a huge Ceremony.
They plan to tour the entire UP system the rest of the summer.
Tom
Come to MI and they will let you drive one.
