Mcrafty1
- Location
- Southern Aroostook County Maine.
I have a new to me JD 4020 with the 24volt starting system, using two 12 volt batteries, I don't believe it's wired correctly. Here's how the wiring is routed now:
Beginning at the starter, a wire from the solenoid on the starter to the negative post on the LH battery, a wire from the positive post of the LH battery crosses over the transmission to the negative post of the RH battery, a wire from the positive post of the RH battery goes back across the transmission to the field post on the side of the starter. To my thinking, the wires are crossed at the starter? unless the system is positive ground? is that the case? Can anyone help me with this? Thanks
