4020 cast centers
will 4020 34 inch cast centers work on Johndeere 60 if I use the clams from the 60.I have 16.9x38 0n the 60 now and would like to go down to 18.8x34 on it.
The axle size is different and the wedge taper is also different. Unless you found 3020-size wedges it will not work. Mike
4020 is 3 3/8 axle I believe the 60 is 3 1/8 .The 4000 and 3020 are all 3 1/8.I sell several dual hubs and not all interchange not familiar with 2 cyl but have sold some for pulling and never heard that they didn't work.
I have the 34 inch castings off 4020 and want to put them on the Johndeere 60. What I need to know is will my pinion sleeve and keyed sleeve will work to put the 34 inch castings on my 60. If not I need to know what sleeves I do need to make this change. Wood help if I had the part No. of what will work. Thanks for any help I can get. Axel is 3 1/8 th on the 60.
