(quoted from post at 18:15:13 10/14/19) At one time,there was a kit available to put a heavy front end from a Case under them. Worthington sold them if memory serves me right. They were a popular conversion for loader use on them.
(quoted from post at 15:06:21 10/16/19) Randy, would you remember what Case front end would have been used?
(quoted from post at 22:23:15 10/16/19) What about a 4010/4020 fixed thread axle ? Those look very nice.
Maybe hard to find? i have seen few 4020s with 5020 front axle. The front axle looks too big, but this works well.
(quoted from post at 08:24:00 10/20/19) The best fix is changing over to a 42/4430 front end...they look good and are much stronger..
(quoted from post at 08:11:16 10/21/19) I've read of this mod. a few times on the 'net Tim. What is the actual diameter of the spindle(the king pin portion)? Just curious as to what we're gaining in terms of size..
Besides the complete donor front end, what is required to install? Adapter plates? Do the donor tie rod ends fit the factory steering arm? Etc....
Can the original 3020 / 4020 6 bolt wheels be used or are the larger 8 bolt required?
TIA
/quote](quoted from post at 08:24:00 10/20/19) The best fix is changing over to a 42/4430 front end...they look good and are much stronger..
From what I can see, the "king pin" is the same diameter between 4020/4430 front axles but the spindle/wheel bearings are significantly bigger.
(quoted from post at 08:11:53 10/21/19)
(quoted from post at 11:11:53 10/21/19)4020 wide frt knuckle bushing(A877R) inside diameter is 1.500 in
4430 wide frt knuckle bushing(R49835) inside diameter is 1.750 in
So long story,short story is 4430 knuckle diameter pivot area is larger than 4020!
(quoted from post at 06:40:42 10/21/19) There is an adapter plate to let the 42-4430 front axle fit,,the construction of the later model front ends are "Much" better, and yes the tie rods interchange,,and you can get 6 or 8 lug wheels..I get them from Anderson Tractor in Bluffton Ohio
