4020 fuel pump replacement
gwece
Can you guys give me the correct steps on replacing the fuel pump on a 1968 4020 diesel especially on bleeding the air out of the system. Thanks!
Disconnect fuel lines,unbolt lift pump,clean off old gasket from block, install pump with new gasket,connect fuel lines,bleed air out of filter,crank engine.
Thanks Jim! Got it done - wasn't sure if I needed to bleed a few injectors or not, but it fired up fine just like you said.
