4020 High crops
I found 2 4020 high crops one 67 synchro diesel and one 69 power shift diesel . Both run and was worked last year. Tires are good but all sheet
metal is shot they do have draw bars and 3 point lift arms anyone know what these are worth ?
Assuming the high crop parts are complete with toplinks,and not welded up with good tags,the 67 should be worth in the $4-6000 range and the powershift $5-8000. If you are buying to restore I would want to be in the lower price range for either of them. Time you fix all the mechanicals,the wiring,wear areas and incidentals and replace all the tin,you could easily be in them for more than they are worth. They, like most others have fallen in value over the past few years, The big money in Hi Crops would be the '72 model 2520-4020 power shifts.
