4020 hydraulics
deereman18
My 4020 sprung a leak on me this weekend hauling manure it looks like the main line that is hooked onto the front pump. It can"t be gotten to thought from the top because of the sheild under the radiator and i can"t reach it fom the bottom to tighten it. Is there an easy way to get to it to tighten it or am I in for some major work? The JD mechanic told me i had to remove the wide front end to get to it I hope there is another way though.
I had pump problems on my 4020 wide front and ended up replacing the pump. I had to remove the wide front end to remove and reinstall.
It's alot easier to remove the front end then go in from the top. I think I did our gas model from the top and everything had to come off.
Seems most of the folks who frequent YT think that owning a tractor is participating in a 'hobby' and would never modify a tractor so it was different from the day it left the factory. Don't know how you'd feel about taking a torch to it.........I've owned five 4020s and my Dad owned either 3 or 4; I think every single one of 'em had a small hole torched in the afore-mentioned plate to allow access to the line in question, using a wrench which had also been modified.
Re-move the front end,,It's not as bad as it looks,,If you have 2 "long" 3/4 bolts (the one's I use are 16 inch) you can put them in the front holes and let the front end 'slid' down on them, this keeps the front frame in place , once you make the repair let the tractor slide back down the long bolts and re-atach it, you can use a couple of dual hook bolts,set a jack back at the rear of the engine at the clutch houseing,double block it "safely" when you get it up where you want it..
The option that thurlow offered is sound and I've seen many tractors that have had the same modification as well...........If you do a good job with the torch and clean up the hole properly afterward with a die-grinder and metal bur, chamfering the edges of the access hole, there's no reason the modification should be unsightly..........However if ORIGINAL is the word of the day in your house, you best be dropping the front end ;)
AND after you put the fire out from all the oil, weed bark and hay dust that has gathered under there,,,drop the front end it's not that bad of job...
You can get at the line by pulling a frame rail also. It"s more bolts than droping the axel but not as heavy bull work.
"AND after you put the fire out from all the oil, weed bark and hay dust that has gathered under there"
You've got a point there! LOL
Although a nifty little invention called a pressure washer will help reduce the chances of fire............
If you have splitting stands or some safe way to support the weight of the front end , remove front axle is easy. If you do not have the heavy tools , support the oil pan with a 4 x 4 and bottle jack and remove side frame rail. Our mechanics usualy remove frame rail because it is faster and easier for them with air wrenches.
From the looks of some of the tractor's I get in here I don't think there are any power washers in Ohio...
hello, i'll add my "2 cents" you don't have to completely remove the front axle, jack or hoist the front of the tractor SAFELY then remove the 4 bolts from the axle support and let it drop down on the tierods, swivel the complete axle a bit either right or left depending on which line you want to wrench. there is ample room to work either line WITHOUT REMOVING the whole axle. this method works for this 41 yr. JD VET.
Any chance you have a hard wood, glass front display case in the shop? Containing the cold chisel used by your Pappy and GrandPappy to change mufflers by chopping hoods?
At least we have running water to use a power washer in Ohio unlike your hillbilly arse that relies on Mule P calling that a power wash.
And by the way, what do you think about all this electricity we have in Ohio?
