4020 neutral safety
2late4me
4020 synchro neutral safety switch doesn't work in park. Wiggle shift lever until almost in first gear before switch makes contact. Switch looks good, something worn inside ?
Remove NS switch then remove a sealing washer or 2. Reinstall switch. If switch doesn't make connection thenloosen bolt on shifter arm & tap shifeter arm further on shaft with switch & spring loaded detent removed. Tighten bolt,reinstall pparts that were removed. If that doesn't help then I suggest installing a new NS switch
