4020 Propane floods
gmac2
I never figured you could flood a propane tractor, but apparently you can.
the 4020 started great, used it to move a bunch of stuff around with the loader, shut it down.
Next morning it won't start, if we shut the vapor off it will fire, open I can see the gas out the exhaust, open it a little bit and it fires and quites. Got it started by opening the throttle all the was and opening the vapor valve a little.
Have not had time to look at the propane carb and see what it does, if it was gas I would know.
I figured the regulator was stuck, but there has to be something in the carb that regulates the fuel to the engine?
Probably the vaporizer. I had one this summer that got a piece of dirt under the low pressure valve and kept pushing fuel through the engine. Could hear fuel flowing when the valves were on. Had fuel vapors coming out the air cleaner and crankcase vent. The fuel displaces all of the oxygen so it will not burn.
Also insure your coolant level is up to par. Sometimes have had trouble with vaporizer if coolant level is too low. Vaporizer has coolant running through it.
Ryan
The choke was stuck closed on mine a while back. Couldn't tell it because the choke lever would pull in and out. Refused to crank.
Well, the regulator/vaporizer works with the throttle body ("carb") and the throttle body is just a butterfly valve that controls engine speed by controlling the amount of air/fuel mixture that enters the combustion chambers. It is true that there is a venturi inside the throttle body, upstream from the butterfly valve, but it doesn't really determine the proportion of air to fuel--that is really done by the regulator/vaporizer doing its job. Call Carb and Turbo Systems in Minnesota, ask to speak to Phil or Dave. They can guide you to what to do to fix it.
