4020 steering issue
Mcrafty1
My new to me 4020 has a steering issue when starting cold, the wheels need to be turned stop to stop before the steering wheel has control of them....after that everything is as it should be. Any ideas? or is this normal for the hydraulic steering on these tractors?
It's a Powershift, I don't need to disengage the clutch to start it...at least I don't belive I do but I'll pay better attention when I start the tractor but I don't rember if I depress the clutch out of habit or not.
Powershifts do not disengage transmission pump.
Your statement is correct concerning tractors with Powershift trans as long as short handle on LH side dash isn't moved rearward which disengages damper clutch. Technically tractors with Synchro-range trans don't require traction clutch pedal depressed for engine to start if trans is in neutral or park position.
