Hey everybody, I'm new here, but very familiar with tractors & implements. I am currently in college taking a course specializing in farm equipment & Diesel. As a project I will be working on my dad's 66 JD 4020. It has 250-300 hours on an overhaul, pistons, sleeves, bearings and etc.. But something has gone wrong. It started out missing on 1 cylinder, but would smooth out if it was pulling hard, more noticeably with say a chisel plow or snowblower. It has a set of rebuilt injectors with about 20 or 30 hours on them at the most, this tractor is a yard tractor now, doesn't see any field time. We also tried to find the miss by cracking injector lines but that still didn't work, we are pretty sure it is number 6 but just cant say yet. Then this past winter I was blowing snow as usual and it began to knock horribly so I parked it and it sat until spring. I pulled the valve cover and pulled one push rod out... (it was cyl 3 exhaust valve) It was bent at about a 10 or 15 degree angle about 4 inches down from the top would be my guess, and then found that exhaust valve to be stuck, it was running fine when i started it and it just got bad all of a sudden. Replaced the bent push rod with a good used one and re started and it still knocks.. I will be pulling the head for sure and check valves and get them ground/reseated at least, maybe replace a few. Also this tractor had a M&W turbo kit on it, with a re tuned injector pump until the turbo started spitting oil through exhaust. It didn't blow the turbo but we removed and replaced stock intake and exhaust for the time being. I would like to rebuild the turbo if possible, I dont want to buy a new or used one, i don't think it would be worth my time. Also would like to convert to a 12 volt charging/starting system. I don't much like the 24 volt and I think the generator is shot anyway.
So, if anyone here has any questions, comments, or concerns about my plans, or additional ideas, I would love to hear them. I love constructive criticism (as long as your not too mean about it lol)
