4020 wiring harness
T-Nason
Looking for a new wiring harness on a 69 diesel synchro side
console 4020. Steiner had one listed, any one used these? John
Deere was about $500 more. Worth it?
Agri-services, www.wiringharnesses.com, is the place to go. They will customize to the starter and alt/gen. you use. Each wire is marked. Installed 4020 early, farmall 400 and moline 4 star. no complaints.
(quoted from post at 19:51:28 10/21/22) Agri-services, www.wiringharnesses.com, is the place to go. They will customize to the starter and alt/gen. you use. Each wire is marked. Installed 4020 early, farmall 400 and moline 4 star. no complaints.
X2
I've used several of these mentioned, but prefer Agri-Services. The only problem with them is there is a backlog and it usually takes a while to get the harness.
I contacted Brillman about something on some wiring and never heard back from them. Not impressed. Would probably walk on by if I needed a harness when it came to them.
I bought a complete wiring harness for my 1964 4020 from Steiner this past spring.
Excellent quality. With included directions, it was easy to install.
Steiner asked me the year of the tractor (serial number), and they wanted to know if tractor was 24 or 12 volt, alternator or generator.
Can't recommend them more!! Pretty well idiot proof, which is what I needed.
John
