Herman, MN.
I have a 4020 that when it gets cold outside, about 10 degrees or somewhere in there, or colder, it doesn't want to start. It does have a block heater, and it does work, the problem is that it doesn't want to even attempt to crank over. If you use a screw driver across the solenoid it fires right off. So far, have replaced the solenoid, along with the starter switch thinking it might be wore out. Bring it in the shop where it is warm and it works fine, but replaced those parts anyways. Sits outside overnight and it has this problem. It's a diesel but don't think this has any bearing on the problem at hand. Any suggestions, or if anyone has run into this problem before, would much appreciate your help. thanks
Joel
P.S. I already posted this on the John Deere forum, but seems like a lot of people on here have a lot of knowledge in general about tractors here.
