bobmiller36
I just had to overhaul my twenty because of a scored piston.The dealer who did the overhaul did a good job my problem stems from their driver who hauled it. It was cold when they hauled it home it was around zero, they used either to stert it and then left it run on the trailor for 40miles to my place. When I went to put the tractor away it is covered in what they call diesel slobber from not getting warm enough.The thing is totaly covered enginn.cab windows,tires ect. my questoin is did this hurt the engine by filling the new cylinders with unburnt fuel? will the rings seat? any help would be appericated thanks Bob
Just put her to work. Dont piddle around with it ,pull as hard as you can(I prefer a plow). Dont idle it anymore than necessary. It needs internal heat to seat the rings and I dont mean temperatur on the gauge.
did you want to kill the driver ? You should be ok . Maybe pull it hard and get it up to 190 or so for a little while , then let it run a about half throtle for a few minutes. Rings will seat when you get them hot most of the time.
I worked for a JD dealer in the mid 70s. When we overhauled a tractor we ran it on the dyno for a bout 4 hours afterwords to break it in a bit. We did the same thing with new tractors that were sold. We ran it for an hour at 1/4 load, 1 at 1/2 load, 1 at 3/4 load then an hour at full load. many times when guys got their tractors overhauled it was in the off season and they just used them for light loads, pushing a blade or something for a while before working them. It also gave us a chance to find any leaks or problems before the tractor went to the customer.
Not that I condone the use of ether, the up here in COLD country it is VERY common to use it, and every 4020 I've ever seen has an ether injection port.
I've NEVER hear of anyone around here having a problem linked to it's use, and there's LOTS of high-hour tractors around here!
4020s have pretty tough piston rings. I don't recall every knowing of a 4020 getting ruined by ether.
On the other hand the little 3s and 4s used in 820s,1020s, 2020s, 350, and 450 crawlers broke very easily. I've seen new engines get detroyed in one cold-starting episode when ether was sprayed directly into the air-intake (orifice not used).
When the fours got turbochargers added, they also switched over to plasma Keystone rings that are much more durable and resistant to ether.
Another thing; I equate diesel slobber to an engine that has something wrong with it like low compression,bad injectors or even bad/missing thermostats.
My uncle used to leave his 2940 sit and idle for an hour or more during lunch time. Never had any problems with it. He actually said he had less starter and battery troubles from doing this.
i agree, the engine was probably not broken in properly after the rebuild. the rings didnt seat well an oil passed by. since it was idling there wasnt enough exhaust velocity to push the oil vapors up and out the stack, "slobbers" are common on some of our old DMM mack trucks that idle alot. get the engine warm temp wise then go out an work it the rings should seat.
Chances are the engine may have been idling too low AND the engine operating(coolant)temp. may also have also been too low while the tractor was being hauled to your place, both of which are huge contributing factors for the slobber you noticed all over your tractor.............
As some have already mentioned, the ether shouldn't have harmed anything providing it was injected through the factory port(with the atomizer intact) or sparingly through the air cleaner/intake...............Used properly, ether will not cause the problems it's infamous for such as broken rings. The keyword being PROPERLY...............
The best thing for the new engine would be to get it under load(and up to operating temp.) as soon as possible..........if after a proper break-in is acheived and engine operating temp. is achieved and maintained, the slobber still exists - contact your dealer..................
rings might have seated ,but i have seen either blow a piston apart in a sleeve,,,use wd40,think there may be a bad turbo on this guys tractor if its diesel pumping oil?
