4020D Sleeve O-ring Pitting
pvdiag
In-Frame rebuild time for this 1966 4020 Diesel Powershift. Block R33180. After cleaning out the cylinder wells, there is some pitting at the o-ring seat. This is #5 cylinder. 2,3,4 are showing the beginning signs of this pitting.
I am the second owner of this, the first being my father in-law. Estimated hrs (clocked stopped at 8600 in 71 or 72) >20k. No major rebuilds or anything. There was a healthy buildup of sludge in the bottom of the wells. No obvious weephole stains/leaks or general coolant leaks for the time I have had it (250 hrs over 12 years).
Some posts here and there say that a JBWeld fix is the way to go. Others would send it to the machine shop. Get a new block or take a chance on putting it back together again round out the option tree.
I appeal to the great Deere engine rebuilders and eye-ballers here for your advice on the most prudent path forward.
Thx
Clean it up real good and go with it,, I use a wire wheel on a piece of 5/8 all thread and a side grinder to clean the grooves,, I will see if I have a picture of it,,if you can get the middle (weep hole groove) clean enough put an o-ring in it too..
i have one customer that has 13 or 14 4020 i don't know how many 4020 404 engines jd tractor i done over the years but all most all well have a bad spot clean it up good go with it.
OK, this makes 2 suggestions to clean it up and put it back together again. Thank you for the response.
I guess I take this to mean the pitying could be slot worse?
Thank you for the reply. As noted above, this tractor doesn't see the day to day action that it used to. Yearly 30 acre bush hogging and running a woodchipper being the biggest loads applied. Also essentially laid up for 5 months every winter. My biggest concern moving forward - especially if I clean it up.and put it back together - is continued corrosion. Will the newer formulation coolants arrest (or greatly minimize) corrosion? Assuming of course sticking to recommended changeouts and all.
ooh yes,,it could be a lot worse,, but those nicks at the top area really won't hurt anything...
I would believe that cleaning up, and using the proper coolant would prevent further corrosion, make sure and keep anti cavitation additive up to snuff.
It looks like you are just doing an in frame; have you inspected the cam/oil pump gear for excessive wear?
