404 Loader : note
marlin54
I forgot to say that on that loader someone replaced the front bucket and it was off a Ford as it was Ford Blue...the cylinder in the center?? not sure it might be original....
They are IH Cylinders I belive from what I see its all seals and not packing...so thats not the issue....the rods have long drag marks not real
deep but deep enough im going to use emery paper and try to work them out ..the wiers look real good so that makes me
believe someone had the originalsseals go bad ..they got scratched up and someone the rebuilt them ..used same rods. but either way with the serial numbers I was
hoping that these same clyinders were used on something else IH had made and by Cylinder number I could reaserch and see what else they went
on..and this would make sense if IH said ..here are the cylinders that were allready using for something else so we will suppy you with these cylinders and you build the rest of the loader? Maybe a combine ? Is there a way to search part numbers? or call a dealer? there are alot of combines sitting in jun yards with very little use ...
