Alan Nelson
Does not start, replaced the selanoid under the hood in front of the dash, still will not start. But can jump off the starter and then it will start, but no power in the cab. Would appreciate and help or suggestions. This is a quad range if it matters.
There are auto reset circuit breakers under the cowl on the left side of the dash for most of the electrical functions. Sometimes they refuse to participate.
I would suggest to check for corrosion/bad connection of wiring bulkhead at RH behind engine on firewall. It wouldn't hurt to check the circuit breaker board Ozarker mentioned but I don't remember starting problems arising from there. Also there's a neutral start switch on RH side of trans case to check for continuity. If NS switch isn't making contact sometimes removing one or two washers(parts key #3) will help.
replace safety switch clean main wiring haranse block dad put jump wire in the safety switch it still no power in cab could that new solined gone bad it a mouth old it start doing these all at once is there some that did get put back on it after the cab was remove had to Built the trans and injet pump that been about 9 mouth go
