4055 deere temp OK?
pg1967
Have a 4055 has a second temp gauge that goes to the head that under load (discbine or round baler) reads between 195 -200 degrees on hot days. No load needle drops down to 170-180. The original gauge with the sensor near the thermostat housing never goes past the middle of the green section on gauge, usually in the first third. Question is the reading at the head normal or is it too hot. Thermostat spec is 180 degrees.
