I picked up a non-running 41 9N a while back and am getting around to hopefully getting it running again. The tractor has been very well maintained and the rubber and sheet metal are better then my 8N that I have used for years. The owner told me it was running the summer before, and when he went to start it after the winter, it would start. I was told it had no compression. I tested the compression and got the following results:
Cyl #1 Less the 30PSI
Cyl #2 Less the 30 PSI
Cyl #3 about 40 PSI
Cyl #4 about 60 PSI
I am hoping the rings are just dried and stuck so I want to start with some MM oil before anything else. I can look in the spark plug holes and see the valves are opening and closing. I cant see if they are seating properly, but I can see that they are not stuck open. I searched around but couldn't find the answer. I know a lot of people put the MM oil in, set for a couple days, rotate the motor, etc. But I am not sure how much people put in. So, how much oil do you guys recommend putting in each cylinder? Do you rotate the cylinders to close the valves before putting any in? I figure I would try this first before pulling the head or doing other major work. Also, have people used Sea Foam instead?
Thanks,
Rob
Cyl #3 about 40 PSI
Cyl #4 about 60 PSI
Thanks,
Rob
