I put the cam and cam drive gears on my engine and I think I've gotten the timing right. I've spun the engine a number of times to check for binding and now it's as if I never timed it. I don't think anyone sneaked in and rearranged the gears as a joke, but the marks never line up at TDC now. I'm assuming it is due to all 3 gears having different numbers of teeth, is that right? If so, if I just line up the marks on the injector pump gear (not installed with the others) with the mark on the cam drive gear will the timing be right? Or do I need to start over and put all 4 gears on at once?
Thanks!
Thanks!
