410b swap to 276 engine
Keith0723
I have a 410b with a bad 219 engine. Will a 276 engine bolt in my 410b? I've searched and believe it will fit just wanted to double check with the pros on here. If it does drop right in is there any other info that I may need to know about doing this swap? Thanks guys
Its a John deere 410b backhoe
Thank you. I would be pulling the 276 out of a 310c so I would have all the accessories. As long as the motor bolts right up I should be good? Anything else that may stop this from working? Thanks
I believe the engine will bolt up fine, the blocks are similar. Accessories and linkage, like the throttle, will be the things you may have to work on.
