411-B case-o-matic
firsttime
Son has a 411B. we are strugggling with the charging system (big suprise). It is 12V positive ground and the generator does charge. It is an autolite system (but generator and regulator are after market). Does the polarity of the system determine the choice of regulators? We cannot find a direct replacement> Thanks, Dan.
Thanks Chuck. I did as you suggested and came up with a couple more questions. Since the current aftermarket generators are 25 amp, I will assume his current one is also. So, a 12-15 amp regulator would seem to be what he is looking for. Positive or negative ground doen't seem to matter. But the question is, what is an A type and what is a B type regulator? Thanks, Dan
A & B refer to the way the field is energized. A's get power from armature hot brush and ground from regulator. B's fields are connected to the ground brush and get there power from the regulator.
