kienkelly
on my international the rear stearing wants to drift to the left. i cant see any bent linkage. i had a friend out who works for case ih and he figures the stearing valve is bypassing.it has some scaring
http://partstore.caseih.com/us/parts-search.html#epc::mr66639ar374354bi612587 18 the link is a parts break down of stearing linkage with the valve being number 18 its driving about a half a tire to the left of the front one so i would like to find out whats going on
Have you checked the 2 bolts going through the shaft under there they will break this will usually let the rearend drift from side to side. Also if you didn't get the wheels straight when you put it in 2 wheel steer they will stay off till you put it back to 4 wheel steer and get them straight. Our problem with the linkage was it would bend the long link by the end of the valve for the steering under there. The bolts first mentioned are on that link to the back end the arm goes straight up about.
