420 slant steer with swept back front?
I came across a 420 ss with a swept back front end, kinda odd for me because I always thought those didn't come out till the 30 series.
Were there many 420s with that front end?[/i]
It is my understanding the swept back front became an option on the late 430W (1960?) Tractors. Probably as a precursor to a similar axle used on the 1010 Tractors. You could also get the swept back axle on the late 435 Tractors.
It is possible a swept back could have been swapped onto a 420; I have seen a couple with them. Not long ago a fella had a pair of 420 Tractors listed for sale with swept back front ends (down south, Alabama? Mississippi?). One was a "W" and the other was a "T;" I dont know that the swept back option was ever correct/used on a T Tractor. The key piece to make sure it is correct for a 430/420 tractor is the bolster (cast piece that bolts to the engine block). It is different than the standard axle bolster to account for tighter turning radius/clearance for the tie rods. A later 420/430 parts book shows the bolster / swept back axle pieces for a W Tractor.
I put a swept back front axle on one of my 430W tractors. . . I think it looks more appealing vs. the straight axle.
(quoted from post at 08:09:17 01/26/13) It is my understanding the swept back front became an option on the late 430W (1960?) Tractors. Probably as a precursor to a similar axle used on the 1010 Tractors. You could also get the swept back axle on the late 435 Tractors.
Thank you very much for the detailed answer.
So then I take it a 420 its just a cobbled up mess with a swept back front end?
Id have no problem owning a 420W with a nice factory correct swept back front end. . . who knows what the dealer did to his tractors 40-50 years ago to appeal to customers.
Personally I like to build my tractors as I would have ordered them back in the day but I only use the options/parts that would have been available at the time -- this way any correct police can unbolt the parts and have no trouble making it the way they want it after Im gone.
Id be less interested if someone swapped the standard straight front with one from a 1010 or if it is obvious the tractor has a variety of "cobbled" parts on it.
I don't know what a 420ss is. But the swept - back adjustable front axle was available for 420 row-crop tractors. Part # AT 11750T
