424 Draft control lever and position control lever
wwoodrow
I am trying to ascertain why the draft control lever seems to be locked in sync with the position control lever. When I move my position control lever then the draft control lever moves with it. They cannot be " separated "or moved independently. I did remove the crown nut and friction nut which holds them tight but that is of no help. Am I seeing things correctly in that the draft control " shaft " is inside of the position control shaft ? Each has its own splined gear on the end with the draft control being at the end of the shaft and the splined gear for the end of the position control a few millimeters inward. Is the shaft hollow and basically a shaft within a shaft ? If so, I am assuming that they are seized together and cannot rotate independently. Has anyone dealt with this on any tractor ?{ I assume other International tractors of similar type are basically set up in the same manner.
I should not have used the word gear. They are simply splined portions of the shaft. The smaller splines on the end of the shaft mesh with the draft control lever, the larger diameter splines which are inward on the shaft mesh with the position control lever.
The unhappy fact is you'll have to remove the lift cover to fix it. There is no way to tell how heavily they are seized together, and there is not enough spline protruding to put any real force on them, without ruining them. Once they are outside the cover, the inner shaft can be driven out of the hollow shaft without damage.
If you can use the 3-point , and it is not affecting the hydraulic system (pump going over relief, for example) , you could elect to just leave it alone. However, if you pull a plow or something that needs draft control, you'll have to take it apart and fix it.
Try shooting some penetrating oil on the bushing where the inner shaft comes out, and try working the levers with moderate pressure. Don't get brutal because you could strip the splines on either shaft.
The tractor has had a slight hiccup in the lift since I bought it 20 years ago. It seems to have gotten worse since I put a new hydraulic pump on it. I can usually find a spot with the position lever which does not jerk when bush hogging but it drops the front of the bush hog too low. It jerks constantly with an attachment like a sprayer which requires raised position. Disking is also no problem. I thought that possibly the draft control being seized to the position control MIGHT have something to do with the hiccup, thus I was looking into trying to unseize it. My other thought is to remove the access panel and investigate the possibility of unhooking the draft" shaft " from the draft linkage altogether.
I have very limited knowledge of exactly how this works but have been studying the diagrams. I am going to unhook the bush hog and put the lift in the raised position to determine if it jerks. If not, I wonder if this means that the draft control is causing the issue.
Hiccups is usually caused by the lift piston, bad oring,(seal). Normally those tube and shaft do not seize together. There's plastic bushing at each end of the tube to support the shaft, and an oring at the very end where the handles are attached, so there should be oil in the shaft for lube. There's also an oring where the tube enters the casting. Moving together, I would think something is locked together on the linkage end??
Mr. Fred,
I have the service manual and believe I have found a test to determine if the piston seal is leaking. Can I raise the lift, shut tractor off, and close the isolating valve? I read that if lift drops after this procedure then the seal is leaking. I have been studying detailed diagrams and also felt that these shafts should not seize since they are contained in the closed fluid reservoir. I suspect I will end up removing the access panel [ for only the second time during my ownership of the tractor ] and checking to see if the linkage is somehow binding.
Question: I have found replacement pistons for this tractor and is this replacement something anyone other than a full time mechanic should undertake ?
No a bad job to get the unit out. The two linkages have to be unhooked. The tub shaft splines are timed. When you unhook it, if you look at the splines close after you remove the handle and quadrant assembly you will see that one spline is tapered off on the end and then the arm that it goes into is marked also. I put a paint mark on both for reassembly. There is a drain plug in the front left corner after you get the cover off.(access panel), lift the three point hitch by hand all the way up and support it in that position. Then you can remove the 4 large bolts and the 2 small bolts and lift the unit out by lifting the front of it to clear the casting and then up. The control valve is mounted to the lift house and there is two prints you need to replace. When you do your test, make sure you have an implement mounted on the hitch.
To get the piston out, remove the valve and then a little air pressure on the inlet port will remove the piston
Thanks,
I tested it with the bush hog mounted . When I closed the isolator valve it did drop very, very slowly, but it dropped. I'm thinking I will pull the access panel when I get time to take a look see . Considering whether I want to tackle the piston. I am building a bigger shop and it probably will not happen before that project is completed. Thanks for all your help.
If the isolator valve is not leaking and the 3pt dropped with the isolator valve closed then the 3pt lift cylinder O-rings are leaking. I believe on 424 you have to lift the top cover to get the control valve section out to replace the O-rings on the lift piston.
