4250 Clutch Temp Light
I have an early 4250 powershift after using it about an hour the clutch temp light will come on and go off, sometimes it will stay on for 3-5 minutes I can turn the key off and then back on and it will stay off for maybe 2 minutes or it may stay off the rest of the day. Has about 8500 hrs. on the tach. Any advice as for what to checkout? Thanks Roger
Type of oil ? Oil level ? Filter replacement was when ? Transmission pressure screen ? Any hydraulic equipment connected to the tractor ?
I use Hy Guard, less than 300 hours on new filters and cleaned the screen at that time, 2/3 the way up in the safe zone on the dip stick, equipment doesn't make any difference has done it with a 7' gnuse bucket at 30 degrees or a JD 946 Mo-Co at 85 degrees.
