chuckthisout
I've got an electrical issue with my 4250. My voltmeter is not working correctly. I have 12.6 volts at the battery but when I turn the key on the needle on the gauge will not even come out of the orange and the manual says that is less than 11.2 volts. When running the needle barely runs in the solid green left of the black. I check voltage at alternator and it's around 13.7 and manual says 13.2 is low end of in specs. Alternator is new and batteries are new. It has two 12 volt batteries. Also, the clutch on a/c compressor locked up and dealer told me if I don't have 14 volts going to compressor, the clutch doesn't engage completly. Compressor is 3 years old. Wondering if these problems are related. Tested the connections on alternator and everything seems to be in specs but on lower end. So I don't know if I have an open circuit some where or could the whole gauge cluster be bad and cause these problems? It has the investigator II. Sorry for the long post but I'm about to pull my hair out and don't want to replace compressor if I don't have the correct voltage. It's hot in that cab right now in southeast Texas. Thanks in advance and any advice is greatly appreciated.
