susandiane
The lower trans seal on the shaft driving the belly pump was perished. I got a new one from Case IH before tearing into it. Turns out that the old seal had a wide casing and two seals in it. My new one has a narrow casing and one seal. The diameter of the new seal where it contacts the shaft/seal retainer is correct. Did I get a wrong part, or do you now have to get two of them and put one behind the other? Room-wise that would work, but I'd rather have the original style. The schematic in the Case IH parts book shows only one seal, but was too small to see if was the double seal or the single seal style. I'm a Green Wennie in tractors and I know JD's have some seal stacks where 2 singles replace an original double. My knowledge of IH is somewhat less than Putin's honesty. Any and all advice/suggestions appreciated!!
