430 alternator
Cg19
Have an alternator from Saeli with tach
drive. The tractor had an alternator
previously. Cannot for the life of me figure
out how to mount this alternator. Was hoping
it'd just fit in place of the one I took out,
but the tach drive hits. Anyone have any
pictures? I'm excited to get my tach back for
sure, but just do not see how this mounts.
Any pictures would be great. Thanks
This is a 1961 model 430 diesel.
Was hoping to see better response here as I'm also contemplating a 10SI with tach drive on my Diesel 188.
Does seem possible to flip the tach drive mounting 180 degrees if clearance to the intake manifold is a problem.
What is the pulley diameter on the Saeli unit?
I did end up getting it installed. I'll try to get some pictures for you. Ended up being able to use the bracket that was made for the alternator that was on it when I bought it. I did have to massage that side panel some, but it seems ok now, and doesn't look too terrible. The hardest thing once I got my head wrapped around mounting and wiring was finding a belt that fit. 50" worked for me
You can change the clocking on a 10si by removing the back half and turning it to the desired position. There are two holes in the back half near the center to insert tooth picks to hold up the brushes up for reassembly then remove the tooth picks after all is done.
