My wife used Chat GP and got a one page reply to all the possible glow plug problems.
On many
John Deere 430-series compact tractors, a warning light that looks like a
light bulb with a coil (or spiral filament) inside is typically the
glow plug / cold-start indicator. It illuminates when the key is turned to the preheat position and indicates that the glow plugs are heating the combustion chambers for starting.
[ebay.com]
What it means:
- Comes on briefly before starting: Normal. Wait for it to go out, then start the engine.
- Stays on after the engine is running, flashes, or appears unexpectedly: This can indicate a problem in the glow plug circuit, relay, timer, wiring, or one or more failed glow plugs.
A couple of questions to narrow it down:
- Is your tractor a 430 garden tractor, a 4300 compact utility tractor, or another 430 model?
- Is the light yellow/amber or red?
- Does it come on before starting, or while driving/running?
If you can upload a photo of the warning light, I can identify it definitively.
If that symbol is indeed the
glow plug/preheat indicator, and it
stays illuminated after the engine starts, I would check the following in order:
1. Determine whether the glow plugs are actually still energized
This is the most important first step.
- With the engine running and the light on, measure voltage at one of the glow plugs.
- If voltage is present continuously, stop operating the tractor until the issue is fixed because glow plugs are intended for short preheat periods and can be damaged if left on. [tractorbynet.com], [external_link.com]
- If voltage drops to zero after the normal warm-up period, but the dash light remains on, the problem may be limited to the indicator circuit rather than the glow plugs themselves. [tractorbynet.com], [forums.yes...actors.com]
2. Check the glow plug relay or controller module
A common cause is a:
- Sticking glow plug relay
- Failed glow plug timer/controller module
- Faulty preheat control module
Several Deere owners have reported a controller module failure causing the indicator to stay on abnormally.
3. Inspect battery and ground connections
Especially if the problem appeared after:
- A weak battery
- Jump starting
- Corroded terminals
- Electrical arcing
Poor grounds and high-resistance connections can create strange indicator-light behavior. Thoroughly inspect:
4. Check for damaged wiring
Look for:
- Melted insulation
- Chafed wires
- Corrosion at connectors
- Loose spade terminals
Glow plug circuits carry significant current, and wiring problems can affect both the controller and indicator lamp. [external_link.com],
5. Verify the light is not serving a second function
On some Deere diesel machines, the same indicator lamp is also used for another warning function (such as an engine temperature-related fault). If your model does this, a faulty sensor or wiring issue could illuminate the same lamp even though the glow plug system is working normally.
Quick diagnostic
Please tell me:
- Is this a John Deere 430 garden tractor (gasoline) or a 4300-series compact diesel tractor?
- What year is it?
- Does the light stay full brightness or become dimmer after startup?
With the exact model, I can tell you the specific relay/module location and likely failure points.
Since it's a
diesel John Deere 430, the symbol is very likely the
glow plug (engine preheat) indicator. Based on common Deere diesel systems, here is the troubleshooting sequence I would use:
Most likely causes
- Glow plug relay stuck closed
- Most common failure.
- Causes the glow plugs to remain energized after startup. [external_link.com]
- Failed glow plug controller/timer module
- The controller should turn the glow plugs off after a short period.
- When it fails, the indicator may stay on and sometimes the plugs stay energized. [tractorbynet.com]
- Poor ground or battery connection
- Indicator circuit problem
Easy checks you can perform
Check #1: Feel for excessive current draw
After the tractor has been running for 5-10 minutes:
- Shut it off.
- Carefully touch the area around the glow plug bus bar/wiring.
- If it seems unusually hot, the glow plugs may still be energized.
Check #2: Measure voltage
Using a multimeter:
- Start the tractor.
- Let it run for 1-2 minutes.
- Measure voltage at a glow plug terminal.
Results:
- 0 volts → glow plugs are off; likely indicator/module issue.
- Battery voltage (roughly 12-14V) → relay or controller is stuck and should be repaired promptly. [tractorbynet.com], [external_link.com]
Check #3: Inspect grounds
Clean and tighten:
- Battery positive terminal
- Battery negative terminal
- Ground cable where it attaches to the frame
- Engine ground strap (if present)
Poor grounds have been reported to cause glow plug indicator issues.
[tractorbynet.com],
Important
If the glow plugs are actually staying powered, avoid prolonged operation until the problem is corrected. Continuous heating can damage the glow plugs and place a heavy load on the charging system. [external_link.com]
If you can provide:
- The serial number, or
- A photo of the tractor and the dashboard,
I can determine whether it is the older Yanmar-powered 430 diesel and point you to the exact relay/controller location.
So I go and start it to move it back to the barn and the light goes out.
