430 loader plumbing question
I just brought home a 430 diesel (1967) with a loader. It is plumbed up with a push-pull switch that allows operation of the three point, OR the front-end loader - but not both. Can this be plumbed up better than that, without a complicated spiderweb of hoses? The three point needs to be tied upwards as it hangs dead with this setup (when I use the loader). I will never need to use both the three point and front-end loader at the same time..... Any suggestions?
You should be able to plumb the system so your Draft-o-matic 3-point, rear remotes and your loader all function at the same time. Hydraulic pressure is supplied to the 3-point, and the remotes via valves on top of the pump/torque tube and under the fuel tank. If equipped with remote hydraulics (not all were) there should be two valves with a cap on top that supplies oil under pressure via a steel tube/rubber hose combination to the draft-o-matic valve under the seat on the right side. Since that is a full-time pressure line one could place a "T" in the line at the cap, and run pressure to the draft-o-matic value and a value similar to the one below. A single lever "joystick" would actaully be more desirable....but I couldn't find a picture to post. Mount the loader valve assembly on the loader frame on the right side and you have a great setup
