4320 Lift arm Right side
williaada
Have been trying to locate the following and seem to be running into issues. If any one can help I would appreciate the help.
Right lift link for 4320 1971 tractor.. I can find left arm lift links but no right arm lift links, anyone know why the lefts lift links are available? Any lead on the acceptable lift link would be greatly appreciated.
4320 correct 3pt draft link length is determined by rear tire size R.H. (USE WITH 18.4-38, 20.8-34 OR 23.1-30 TIRES) is PN AR80666 Smaller tires uses PN AR26944
Thank you so much for explaining that part. I can get one
from yesterday tractor then.
On lift link can I order the left lift link part numbers:
AR65382, AR26945, RE44094, AR26554
Guessing I can go to deer and order the right side
threaded rod for depth adjustment. Does this make
senses? Also, what is the cause for the right side to be so
much more difficult to find parts for?
