435 baler feed gauge adjustment
RandyK
Got my monitor working (previous owner tore wire off and had it wired backwards). Right side feed gauge needle goes all the way to top of gauge and stays there. Left side works great. Reading that these can be adjusted? How? thanks
Have you checked to determine you have electrical continuity from monitor to sensor? Sometimes the pins & sockets in the wiring quick disconnect between tractor & baler get distorted.
I havent yet but plan too. I was just confused as
I have read about people adjusting the gauges and
I had no idea what that meant. thanks
Relocation of the potienometers(parts key 8) aka sensors is how one adjust them. Slight relocation makes a big change in monitor gauge needle.
Got it, thanks. I dont' think that is my problem
now that I see that. I moved the arm (part 6) and
the needle never moved, so I don't believe
adjustment is the problem. thanks again.
