44 massy sp.
Does it have that "live" PTO function - that's a separate lever on the right (as you sit in the seat) and forward of the operator. That function has been a source of slippage in some units and may be slipping under load. I'm not familiar with what you mean by "planetary is turning".
I'll bet your LPTO disconnect on the right side has oil on the linings and slipping. Dad drilled his MH 33 LPTO for two 5/16 bolts to stop his slipping as he didn't use it anymore..
I see now, … I have a Minnie u with that goofy setup. pretty hard to figure out a problem here with no info and not even the tractor model. have to guess as the likely synario, and massey harris 44 special.?
