#44 plow rope clip
Johnny50
I saw in Green Magazine where there is a clip made to put on the back of the tractor seat to attach the rope and it allows the rope to break away if the plow does. I forgot who makes these.
Where can this clip be purchased?
actually wasn't there one that went on the clutch handle too. if you plow broke loose it would pull the clutch lever at the same time to make the tractor stop. wasn't to popular as i remember because it caught you off guard and nailed your knees. don't hold an old man to this story
That wasn't for the the lift rope though. It was used on hydraulically controlled plows where the plow hitch was fastened to the tractor without using the trip hitch. If a trip hitch was used with the hydraulic, it would break hoses before you could stop the tractor. So the mechanism fastened to the clutch would tighten and release the clutch as the compression springs in the plow hitch compressed. Obviously this happened much faster than a driver could react. I ran a John Deere "R" with a 4-16 plow with this setup. It worked good and I was instructed about always keeping your right leg (knee) off the line of the clutch lever coming back.
When I was a teenager, Dad had a rope trip plow. We always fastened that trip rope to one of the plow depth control levers. Those levers were always pretty close to the tractor seat and we could reach the rope from the tractor seat. So no need to re-hook the rope each time the plow unhooked and that saved time as we had quite rocky ground in ND.
At home we just bent a piece of #9 wire in a very narrow exagerated "U". Then tied a knot in the end of the rope and dangled the knot through the "U". When you lost the plow it would bend the wire straight. I do it that way yet today for plowing days and etc.
Right--NAILED your knee GOOD..!!
I always expect someone to show up with a newly restored "B" at a "plow Day" with this et-up and s
see him get Blasted by that clutch handle...!!!
Been there many times and every time meant it to be the LAST time..especially in 3rd..!!
Ron..
