44 rear end
I have a massey harris 44 and the rear end leaks after driving. it comes from two litle holes on botttom of the rear end. the holes are one on each side right below the the breaks and the clutch petals. what could cause this?
Leaking out the shaft seals for the pinion shaft. Behind the brake drums, will need to remove brakes and drums. If they have leaked for a long time the drums may come off easily, or maybe not. Seals are available from most auto parts stores. Someone over ob the Massey board has the number you will need. Search the archives, was talked about not that long ago...
