44 Special-Need Help
waclar
Took the steering gearbox apart to replace the gasket. Found that the lash adjusting sleeve was broken. Currently searching for the sleeve but guess I will have to get the whole gearbox from someone. Are the gearboxes the same as on other models(22,30,33,55 ect)?
Give Sam's Tractor a call. They handle alot of steering parts and they should be able to answer your questions.
samstractor.com
The 81/20/22 boxes are the same with the exception of the input worm shaft. They are different lengths. All of the rest is the same.We did the swap on my buddies 44 special. Used the best parts from both to make one nice one. Good Luck.
