Just put your new valve ahead of the loader valve and use the power beyond on it to feed the loader.valve. A single spool valve and power beyond sleeve for $103 delivered.I have 1966 ford 4400 loader 3 point i would like to add another valve so i could put grapple on bucket any way to do this I looked at it no ideas dont what to spend a lot of money on it
Question for you, I have a front pump on my 4400, it appears to be a 21 gpm pump, if i did this to my loader, would it hurt the overall performance of the lift and responsiveness?Just put your new valve ahead of the loader valve and use the power beyond on it to feed the loader.valve. A single spool valve and power beyond sleeve for $103 delivered.
TOH
Monoblock Hydraulic Directional Control Valve, 1 Spool, 11 GPM
Monoblock Hydraulic Directional Control Valve, 1 Spool, 11 GPMsummit-hydraulics.com
It wont hurt performance if properly sized. If the pump is rated at 21 GPM I would suggest a larger valve. This one would work fine. I am also assuming your loader valve is a two stick vs joystick?Question for you, I have a front pump on my 4400, it appears to be a 21 gpm pump, if i did this to my loader, would it hurt the overall performance of the lift and responsiveness?
My current loader (735) has the two valves with a float function. Unless i find the exact valve and add in another portion to the stack, it'll be easier to replace the entire thing with a three valve kit, then move my existing valve down stream for a rear remote.It wont hurt performance if properly sized. If the pump is rated at 21 GPM I would suggest a larger valve. This one would work fine. I am also assuming your loader valve is a two stick vs joystick?
Monoblock Hydraulic Directional Control Valve, 1 Spool, 21 GPM
The Monoblock Hydraulic Directional Control Valve, 1 Spool, 21 GPM uses a compact design that allows for installations in tight areassummit-hydraulics.com
TOH
The tractor community generally things float is a worthwhile feature on rear remotes.My current loader (735) has the two valves with a float function. Unless i find the exact valve and add in another portion to the stack, it'll be easier to replace the entire thing with a three valve kit, then move my existing valve down stream for a rear remote.
You may know, so i'll ask, when i upgrade my valve, should i pull my float our of the picture and close up the lines, or keep the float function and buy a valve that doesn't have the float function?
