4430 Brakes
On this newly acquired 4430, the right brake pedal is sticking. I can push it in but have to pull it back to release. Left brake works fine. Suggestions? TIA!
The upper piston is sticking in the bore,or the pedal pivot point is rusty,,is this a cab tractor?,,if it is the valve normally don't see much moisture and it may work out of it if you pull the right cowl and spray some lube on the linkage area,,if it is open station it may have some rust that will need cleaned up.
