4430 rear end noise
Bigiron
76 4430 powershift makes a loud growling noise most
noticeable in 8th gear and only when you pull the throttle
back to slow down quickly. If you slow down gradually it
wont do it. Thanks
(quoted from post at 20:33:11 05/02/22) 76 4430 powershift makes a loud growling noise most
wont do it. Thanks
I had one that did that. Bearings were completely gone out on the differential bevel gear. Shafts are very short on them and I guess they can go out.
It did not make that much noise compared to how bad it was inside.
Serial number and axle diameter ? How long do you plan on keeping and using the tractor . Don't use the tractor, the next new sound could increase the repair cost.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/83395/referrer/search/pgId/210620
https://partscatalog.deere.com/jdrc/sidebyside/equipment/83395/referrer/search/pgId/210656
Mine did not have the axle bearings out, but the bevel gear bearings out, the bevel gear is the one driving the crown. This became a parts powershift trans. The engine was very good and I put it on the front of another 4430 QR with a bad engine. I sold the powershift cab and few other parts and the other parts tractor did not cost much then.
The clue of the problem was huge amounts of iron in the transmisdion sump screen.
A little owling down hill with a powershift is normal, this one was super owling...
When it makes this noise I can step on the left brake and the noise goes away. Probably unrelated to that, in 8 th gear I can step on the brake and make something slip, let go of the brake and tractor takes off again. Hoping thats the torsional dampener and not one of the clutch packs in the power shift. If the pto stops when it slips is that a for sure sign it is? Thanks
