Allen Goodman
Needing help. After 82 years of farm equipment and salvage business in Southeast Colorado, we sold the properties and closed the gates for the last time on December 18th 2020 and moved to Sierra Vista, AZ. Thought I was going to take it easy and do a little traveling until I seen a Estate Sales ad that listed a 444 diesel with loader, grader blade, and 6 ft rotary mower. I can't pass up the color red. Called the widow, got her address and the wife went to look at it. The widow stated that nearly 2 years ago her late husband hired a local man to replace the clutch but he never came back to finished the job. When we opened the machine shed, the tractor was split sitting on jack stands. It was nearly put together. I asked the widow why wasn't the tractor finished. She stated the the guy got frustrated trying to slide it together ended up breaking 2 bolts off in the bell housing and breaking the belling housing around the starter. I searched the shop and couldn't find the broken piece. We bought the tractor and attachments along with a couple trailer loads of shop tools, mowers, garden tractors and miscellaneous items.
After taking everything else home, we began to work on the tractor. We split the tractor all the way again to verify in fact a new clutch was installed. Upon inspection I noted clutch housing was cracked in several places indicating the clutch was not aligned before trying to slide it together. I took the clutch and seen there was a new 4 button clutch plate installed. The old clutch plate was on the work bench and it was the normal Lucas plate. Now I figured out why the bolts and bell housing was broke. They tried to slide it together by tightening the bolts failing to align the clutch. I've contacted several salvage yards trying to get the piece of the block. I have the tractor at a machinist at this time. He thought he would be able fabricate a spacer but decided the best thing be to try and get the casting. So if anyone can help locate a un-serviceable BD154 (British built) block, casting number 3040912R4 I would appreciate it. Thanks guys!
