4440 engine into 4450
matthies
Location
Stanton Nebraska
Guy has an engine out of a 4440 that he wants me to overhaul, then put into a 4450 he has. Any issues other than the water pump? Maybe frame rail mounting?
The frame mountings will not match up,,the bolt pattern is larger,,every thing else will work out tho..
I "think" you can change the side frames to the older bolt pattern,,Deere changed the bolt pattern about then ,,all else will work out..
