4440 hydraulic leak
isuvinny
I have had a small seep of hydraulic fluid coming out somewhere under the remote levers in the cab. Last night I moved the tractor and when I parked it - it dumped a bunch of oil out. Something must have finally given out? How do I get in there to figure out what is going on? Is there access from the cab next to the seat? Thanks
Nothing in that area inside the cab to leak. Since it dumped out, I would be looking at an elbow on the front right corner of the three point housing. Start under the battery box (nonstep side) and follow a 3/4 inch steel line that comes from behind the frame rail and follow it up to the elbow. There should be a bolt/block to fasten it too the housing, this may have broke off or backed out, causing a vibration to either crack/break the steel line of the "elbow" to come apart and leak. Don't be surprised if the elbow just came apart as the elbow swivels and is has a snapring to allow it to swivel and after time just falls apart. Hopefully your tractor rear tires are set wide to get in there. A nasty job as you sit there with oil running all over and on you. Thinking you need a 1 1/8 or 1 1/4 wrench for the line and atleast an 1 1/2 maybe 1 5/8 for the elbow. And you will have a little resistance getting the elbow started as you have to push against a spring.
