meangreen71
I got a 4440 quad range. Had a new front hyd pump put in a few years ago. the hyds have never been quite the same since. problem is. all works fine till the oil is warmed up and then hyds seem to slow down. even the steering seems to get alittle harder also. funny part is like when its hooked to a hyd cylinder sometimes it will raise fast like it should and sometimes it raises quite abit slower. the hyd speed control is set as fast as it can go. i have changed filters and they seemed clean even cut them open. sometimes the hyd hoses seem to pulsate when raising. could it be sucking air from somewhere? what do you guys recommend i try next? any help would be apprieciated. thanks. btw the front pump was replaced because the seal around the shaft kept blowing out everytime it was replaced.
