I am wondering what a 4440 like this might be worth about today, unknown actual hours, a lot of work done such as front end re bushed new fluids and new belts, new tires, 3 remotes, water pump just rebearinged and resealed good ac good heat, quad range, all lights and gauges work, axle mount duals, wheel weights, no calcium, new JD toplink, new sway blocks. upgraded step and upgraded air ride seat, fresh interstate batteries, good brakes, good glass, and runs perfectly normal, no oil/coolant usage and still wire on pump, could dyno and be sure it's not tuned up but seems normal.
I accidentaly posted too soon, front end tight, and moves, not frozen up, no leaks, radiator appears great, starts normal, lft arms don't bleed down, and paint went bad about 2001 I would guess. radial rears, good oil pressure, 540/1000 shafts, pto good, and by all means of my evaluation absolutely field ready, Fuel it, grease it, and go right to work.
Sellers would ask 30k for a tractor in that shape here.....and it would not be listed long. 30k CAN is about 22k US
Ben
WOW! thanks good to know I was thinking 16k-18k USD so anything under $20k sounds reasonable for both buyer and seller, air stack is there and side things above batters boxes there too, just removed for inspection.
